Neotec nt-25e wavy picture
pun84
New Jersey
Hi, I have a nt-25e that seems to have a wavy picture. When I put a crosshatch pattern on the screen, you can see a slight oscillation on the vertical/horizontal lines as well as a general waviness on the picture sorta like water.
I ended up pulling the chassis to check the caps, and almost all of them checked out perfectly yet the problem still persists.
I then checked the B+ and it was a bit low at 115VDC instead of 125VDC. After all that the picture is still wavy..
Is there anything else I should check?
also: the yoke seems to be pretty damn warm bordering on hot, is this an issue?
thanks
