here what i have. there was a manual in the game, see pics. the manual says 2515c/nt-25E
the tag on the neck says nt-35c . i did notice things in the manual that arent populated on the chassis boards. anyway, i replaced the 8 leg IC in the power supply , i forget the #, 4602 or something . i also checked B+ , with the chassis anode and dag connected to an old tube( no yoke connected). B+ was 127, now adjusted down to 125. the other voltages from the manual tested good. i got the 24 volts on pin 9 of the flyback, but it was AC referenced to ground. on DC i got nothing, so i assume it is AC, as the manual said its a peak to peak measurement. also, at the anode, i get 10k volts.previously, i was getting zero volts on the anode. 10k is low, but why? no yoke? im tempted to take a pretty long drive and try it in the game. i didnt pull the tube, its a maximum force, and pulling the tube is some heavy work.
thinks its a decent chance this will now work in the game?
thanks
