I'm working on my Rush - plays blind. When I pull the back off and power up, I get no glow from the tube, don't hear the static charge? that I normally hear when you power one up.
Checked all the fuses, made sure the chassis is getting power. Double-checked all the connections, reset and everything looks good. Reseated the neck board etc.
I seen this sort of work when I picked it up - thought the chassis might need to be capped. Since getting it home, it has never worked and I finally found some time to start looking at it.
Neotec 27E with a Zenith tube - Any ideas on what to check?
