Neotec 2702 makes "chirping" noise, no power
GuidoTorpedo
Maryland
Any idea what this could be? This is a VGA monitor from an Arctic Thunder.
Thanks!
-Mike
Or the big poly cap at C423 has blown up, taken out the HOT, Flyback has hairline crack and a few bad electrolytics along with all of that.
Check the (two?) other Mylar caps in this area, too. Apparently they will show bad on a standard capacitance test with your multimeter if they are bad.
Check the HOT too, like mentioned above.
I had a NeoTec NT-2701 doing the same thing mine was just a cap c423 I posted what I did to fix it here. http://www.arcademonitor.com/blog/repair.php?monitor=5
I'm working on one of these right now, the C423 is failed, capacitance tests indicate that it's done. The physical damage (typical with this cap) is NOT obvious on mine. A small hairline crack near another component. Make sure you look carefully if you are investigating for physical damage.
Pulled c423 on mine. No obvious physical damage... until I got it out. Cracked on one end and reads open with a cap tester....
what's everyone using to test caps? feeling like adding that to my arsenal soon.
any different from an ESR meter?
