neotec-2700 monitor issue
Pennsylvania
I have a rush 2049 machine the screen shut down to a white dot then shut off and started clicking. I pulled it out and tested it. I think the PH101 is shorted could this be the issue. The HOT and the fuse and everything else looks to be okay. If it is the PH101 (thermistor) were can I get one?
Thanks for the help
Brandon
Timeline Arcade
Sounds like maybe the flyback took a dirt nap since all the hot or vr didn't die. I've was playing a game one day and had same exact problem happen on me, had to replace flyback to fix.
If its a Neotec then its a flyback. Common failure in this type of monitor, especially in a Rush. Replace the flyback first and might as well replace the HOT since sometimes they bite it with the flyback.
