NeoTec 19" Monitor CGA
BSK
Ohio
Hello technicians,
I am in need of adjusting my brand new out of the box 1.5 yr old 19" NeoTec CGA monitor because it has a convergence problem with the green. It seems that the green is more of an outline to the drawn shapes than a nice color mix. I have done some research with Google and found that the 25" NeoTech manual NT-2515C is sufficient to work off of but the convergence method is missing a diagram to point out what set of magnets are the 4 pole and which ones are the 6 pole and identify the other set of adjustments that may be the Purity adjustments. I was reading a K7000 and found a nice diagram that designates each set of rings and their duty but are the rings on the NeoTec monitor in the same orientation as the K7000? Nothing like having to adjust a brand new monitor... : (
??? brand new out of the box 1.5 yr old
What model is it ?
Degauss first before messing with the convergence.
Any monitor manual will show you which magnets control which adjustments - they're all the same. Just look at the G07 manual or something for reference.
-Ian
Yeah new out of the box! I purchased them because they were cheap and before the extortionist could get a hold of them and over price sell them. I let it sit till I needed it and now I have to adjust the smack out of it. The model number is an NT-1000....
Ok so the magnet set up is the same as a G07. Great! I will degause it and adjust!
Thank you
Brian
