SOLD - PARTS NeoLoch LCD 28 Pin RAM Tester
hackbar
California
Rating - 0%
0   0   0
NeoLoch LCD 28 Pin RAM Tester. Tests all sorts of RAMs with a nice LCD display.
Free shipping!
From their website (https://www.neoloch.com/products/NLT-28P-LCD-5S.php):
RAM Tests:
9114*
2101 / 5101
4016 / 6116
2465 / 6264
6810
7489 (adapter required)
5189
2465 / 6264
W24257 / 64256
Most RAM that is pin compatible with the RAM listed above can also be tested.
Other Features:
Address verification test.
2 x 16 character LCD display.
2.1mm DC power jack.
40 pin PIC16F1519 microcontroller (programmed with RAM testing code).
28 pin ZIF socket.
5 Control Switches.
Programming port.
Onboard voltage regulator.
40 pin socket for MCU, allowing the use of a wide range of Microcontrollers.
4 mounting holes.
5V or 12V selectable power source (power source should be able to supply 300ma.)
