NeoGeo with one coin slot
AtariShag
Utah
I've got a NeoGeo one slot board but it's set to take one coin on each side of a typical two coin door - coins in the left side go to player 1, right side to player 2.
Is there a way to change that so that I could put it into a cabinet that has only one coin slot to use so that all coins will activate either player instead?
You could wire it that a coin adds a credit to both players easily enough, but if you want it to somehow give you the choice of which player gets the credit then you are into the realms of redesigning the game code to add that functionality to the game, or designing / hacking a coin controller board with some sort of switched input to determine where the coin credit goes - either way its a tonne of work.
Thanks, that's kind of what I figured that it might be a wiring issue. I just wasn't sure if there was a setting somewhere that could be changed but I see that there isn't. Thanks
