Neo Geo Video Ram error
shatter1
Lubbock, Texas
I'm going through a few neo boards and ran into this error on a 4 slot board.
Video Ram Error
Address Write Read
00000903 5555 5554
Any help would be appreciated.
thanks!
One of the surface mount SRAM chips is bad - one that is hooked to the video chip. (The other 4 are connected to the CPU... and 2 of those other 4 are powered by the backup battery and are the backup RAMs.)
MV4: Bad SRAM is hooked to the LSPC chip
MV4F/FT2/FS2: Bad SRAM is hooked to the LSPC2 chip...
There are 2 of them on the board, but only one is bad. Check my SNK repair logs and you'll find the location of the chip you need to replace based on the error message.
If you can't do the surface mount soldering, I can and do.
RJ
Check for battery damaged tracks before you pull any chips off, Neo Geo batteries are very prone to leak due to age and this cuts through tracks very quickly, to the extent that even if you have a mint looking board with an old battery on it you should cut it off as it can go from mint to trashed within 6 months.
Hey guys was wondering if someone in this old thread has a map for my Neo-Geo issue so I can find my bad ram.
Video Ram Error
Address: 00000600 write: 5555 read: D555
Also can you do NVRAM on these to get rid of the battery? Thanks!
