pincade
Neo Geo MVS-2 Help - Coin 2 only gives credit to Coin 1?
Hi working on my first Neo Geo 2 slot and noticed an issue I was hoping you could help with:
***edited for clarity****
The issue is that no matter which coin chute I am putting coins in (player 1 or 2) it only credits player1 on the credit display.
So when I coin up, no matter how I do it, only the player 1 credit display gets the credit.
However Player 2 can hit start and 'steal' player 1 credits at any time. And it will correctly deduct from player one's credit display when doing so.
How do I allow a coin put into player 2's slot to register as Player 2 credit instead of always giving credit to player 1?
-The coin switches register properly on the hardware test. Each triggering individually when using the coin chute trigger.
-The Led displays also are working correctly as shown in the hardware test.
-I tried moving dip switch #2 to 'on' but it did nothing different.
-For some reason in soft dip settings for the cabinet coin 2 was set to 2 credits per coin (and would thus end up giving 2 credits to player 1 per coin) ; I changed that back to 1 credit per coin.
-I reseated the harness to the board, but that did not help.
-The coin switch wires seem to be separate of one another with coin 2 having a blue wire and coin 1 with a green wire.
Any ideas?
Any ideas?
