Neo Geo MV-1F 1-slot PCB, asking $50 Shipped USA
keithsarcade
St Peters, Missouri
Neo Geo MV-1F 1-slot PCB $45 Shipped USA
She works, but multicarts are resetting constantly with it, I am being told its a compatibility issue. Dont have any MVS carts to test it with, but I assume it works just fine with those carts. Contacts have been cleaned and reseated, and the bios chip has been cleaned and reseated. Battery has been removed, works fine without it, but dosent save settings. Looks like this one here, but with a metal tray. It has socketed bios and support for memory card readers, stereo sound (has mono/stereo switch), MVS/AES controllers and headphone jacks.
$45 shipped USA. Any takers?
May want to turn it of freeplay if it is set to on. I have a 1F and with my neo 111-1 cart it resets all the time when I have it set to freeplay. I turn it off freeplay and the resetting still happens once in a great while but nothing major.
The multicarts like the voltage a lil' low, too. Make sure you don't have your cab set on 5.1v.
Tried every voltage setting imaginable and still have the issue. Ill try turning freeplay off but I wont be happy with it either way. I keep hearing that the multi's just dont like the older 1-slots. I'm going to buy a newer model and keep my fingers crossed.
Guess I should mention I'd trade for a newer one if anyone's interested.
Tempting like i said before, but.. what all else hardware wise would one need before machine a bench setup of this run :)
Yes, the newbie ;)
This is just the PCB. Unless you have a JAMMA setup already, you need a JAMMA Harness, monitor, control panel, power supply, so on and so on. Then you need MVS carts to play.
ok. =)
ok, thats about what i figured....
I aint got JACK yet...
I have a freind who's bro has tron and a TON of coctail classics pong n all, and sadly he lets them sit and rot.. Hasnt touched in years, the other day i asked him whatcha doing with thoes he freaked out dont touch em!! ROFLMAO..
I don't believe this hasn't sold yet -- $45 shipped for this is dirt cheap. You might want to try neo-geo.com/forums, I bet it would be gone already.
