Neo Geo multi cart problem
tomtime
belton, Missouri
So I bought a 161 in 1 a few weeks back and it worked perfect in my 4 slot. A couple days ago it wouldnt let me return to the game select screen.
I didnt change any settings either. Any thoughts?
Mine did the same, used to go back to the menu fine, now it won't. I can try upping the voltage a bit and see if it helps.
I was researching this today and think I found the solution (for my situation at least). I recently repaired the memory card slot on my 4 slot Neo and apparently if you have the memory card inserted it won't go back to the menu on the 161-in-1.
Solution:
You can still use it to save/load games, just have to remember to pull it before trying to go back to the menu.
Here's the original post on Neo-Geo.com: http://www.neo-geo.com/forums/showt...me-Breakdown&p=3349483&viewfull=1#post3349483
Will test out and report back.
Verified that this was the problem for me. Pulled out the memory card and was able to get back to the menu no problem!
