Neo Geo monitor on and off
Mr Do
Donor 6 years: 2012-2013, 2015-2016, 2019, 2025
Basking Ridge, New Jersey
Got a model 25K7191 chassiss that stay on between 10 and 15 minutes then the monitor goes out.
I then turn it off, then wait a few minutes, and then I turn it back on and the monitor is working.
Anything its notorious for to look at first?
monitor
So I ordered the fly and cap kit and filter cap.
But happen to find a cap kit on hand. I did the cap kit and as I was adjusting the monitor since it was showing a picture, the monitor went out again.
I gave until fly back arrives
When I get fly back and filter cap, I will change them and see outcome.
it's probably because your voltage regulator is bad and the B+ is pegging to the point of HV shutdown. I think when it hits about 170V it will shut down.
there's 2 flavors of voltage regulator -- 4 if you consider 2 of 19" and 2 of 25" (they run different voltages). in either case, just make sure you match up the numbers that's on your current one.
there's a K7000 sticky thread if you want more information about parts identification. I encourage you learn how to test B+.
