neo-geo joystick question
Ryan2Game
st.louis, Missouri
Just purchased a neo-geo cab and I am a little confussed. I have mutation nation, areo fighter 2, the art of fighting and baseball stars professional. The problem is I can't move in a diagonal direction. Example = areo fighters 2 I can only go left,right,foward and reverse I can't move left-reverse in a diagonal motion. 2nd example = art of fighting the character only jumps directly up and will not lunge forward with a jump kick unless I can get him to bounce off a wall. Is this normal or are the joysticks bad???
your right
Your right I just looked up pictures of an 8-way & 4-way. It is defintly a 4-way. I AM SO SCREWED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Some joysticks can be changed from 4 to 8 way by removing the c-clip, turning the actuator over and replacing the c-clip.
Do yourself a favor. Spend $20 on new joysticks and spend 5 minutes replacing them. You probably needed to anyway. Especially if your going to play Neo fighters...
I'm going to replace the joysticks and buttons on my six-slot.
