NEO GEO four slot RAM questions...
Tupin
Wildwood, Missouri
Got a NEO, has a few problems, the main one being that when it boots up, you see this:
VIDEO RAM ERROR
ADDRESS WRITE READ
0000060F 55555 1555
What chips need to be replaced/what needs to be done?
Also, how do I replace the four lights above the cabinet? Any idea on how to pick the tubular locks?
The most common fix for the lighting is to replace them with a fluorescent tube. The units themselves are expensive, and hard to find, and a common fail point.
You can drill the locks out. On mine, I just took the back off and removed the coin door, then took the locks apart.
As for the RAM error, not too sure, but check a manual, or schematic if you can find one. There are a few guys on here that specialize in Neo Geo repairs, so you can check them out.
