Neo Geo cap kit
lopan2008
Strasburg, Virginia
I would like to do a cap kit on my Neo Geo monitor. From what I can find it is a Zenith G-A63ADG25X, 04RC0105-009, serial # 100990. I have checked BobRoberts with no luck, any suggestions as to a good place to find this kit?
Zenith is probably just the tube..
Need to know what chassis it is...
I'm guessing a wells Gardener 27k
If it's a 25" monitor and has P538 on the chassis board then you have a 25" K7000 usually 25K7191.
You can order the K7000 cap kit from Bob Roberts. My MVS cab uses one of these as well as most of my other games.
Thanks for the responses. I figured that wasn't the right number. I will have to do some more investigating tonight.
Next question: How do you get the back off the cabinet without breaking the pressboard? (Or am I missing a secret latch that will grant me access to the wiries and bolts for the monitor?) All I have been able to figure is you have to pull the staples since there is no proper back hatch to the machine. Most likely since the carts go in through the front. Seems someone has secured the wires to the back part of the side panel, well out of reach.
If you have a dedicated Neo MVS cab, you pull the monitor from the front, but there is also a spot in the back that will allow you to get the chassis. You don't really need to pull the whole monitor for a cap kit. Mine also was a 25K7191 I think when I did mine about a year or so ago.
Some models of the cabinet make it VERY hard to discharge the monitor from the service hatch. I would take the whole monitor out in this case. My 1-slot is impossible. On my 6-slot I was able to do whatever I wanted to from the back hatch.
OK, I am a bit dumbfounded. I have the back off of the machine and the front glass/inlay off the front, and have looked on every visible inch of the chasis for a model number. So far all I have turned up is a serial number: 92051073. My cabinet is a MVS-2 but I am not sure if the monitor has been replaced since the coin door was replaced at some point with a HAPP model. Can anyone give me some guidance as to where to find some identifying number. I have attached a few pics of the chasis incase it can be identified that way.
I'm going to help lopan with his cap kit. If we can't find the exact kind of monitor, we could still just identify all of the caps and order them individually, right? It's kind of a pain in the butt, but that might be what we have to do.
