Neither cab worked at all; only 1 had any picture, and the display showed a video ram error. The other PCB was also failed with a backup ram error. I immediately cut the stock backup battery out of both PCBs and fortunately, neither showed signs of acid damage.
My first goals were to take inventory and source parts that couldn't be repaired. Both cabs had K7000 19" monitors, Beta had a k7000-A variant. While this variant is somewhat maligned because of a un-obtainable flyback, my personal experience is that the construction of the this variant is a bit more robust. Probably why this monitor was working, while the vanilla k7000 was not.
I gave both PCBS a good cleaning. Right away I noticed some corrosion in the backup ram area on the "B" cab PCB. A scrubbing with some IPA resulted in a functional PCB! It was a much-needed early win! Unfortunately the next day it threw up the same backup ram error, so I did some continuity testing and discovered a faulty trace, which I repaired and the board worked great!
View attachment 589005View attachment 589006
The other PCB was a different story. With some help from the folks at the neo-geo forums I identified the faulty video ram chip from the error code. After replacing the ram chip, we are 2 for 2 on PCB repair!
