You have a pic of the harness? Im missing mine and im trying to create one.The EL squares are most likely totally dead by now. But glowhut has great replacements. Thats what i used in my 4 slot marquee So even if the EL squares are dead this is still a good buy!
Is it just two JST .098 connectors ? Just plug one on the pcb and the other on the ELA inverter?@jjhudgins
The 8 pin harness you are looking for from ELA pcb to the main mvs pcb? I can get a picture but I wont be near my machine for several days.
As far as i remember yes. Again, this was 7 years ago since i last worked on it, and the machine isnt near me at the moment.Is it just two JST .098 connectors ? Just plug one on the pcb and the other on the ELA inverter?
Just following up brother! I appreciate the helpAs far as i remember yes. Again, this was 7 years ago since i last worked on it, and the machine isnt near me at the moment.![]()
Interesting....i believe my cab is the first version of the 4 slot. It is simply model number MVS-4. It doesnt have the black part of the cabinet under the control panel(see pic). It is possible they changed the design for your revision. Id have to check the manuals but this is how my cabinet was. The only thing I have replaced is the power supply with the direct suzo happ replacement (approx 8 years ago), and the glow hut panels.I wonder why it isn't powered from the pcb. I sourced a cable from France over the last week and replaced the panels with Glowhut Leds. A6 I think. But I haven't turned it on yet bc I wasn't sure if it would work. Let me finish it up and install It and I will post results. But to clarify, I have a 8 pin to 8 pin harness connected only to the PCB and Ela inverter. All 8 wires are connected on both ends.
