FS Game: NEO GEO 138 in 1 - 95 Shipped
Bump for a great cartridge!!!
I'd buy, but already have one.
This allows you to turn off games and has screenshots on the menu.
BEST multi-cart by far, only drawback is a longer load time, but your buying to play and it also has bowling and dodgeball......
Menu makes it well worth the buy!!
Adapter
The adapter goes inline between the MVS Motherboard and the JAMMA Harness to allow for game menu navigation.
The cart is designed for the 1 slot, but some have made it work with multiple slots.
+1 on all of this. The load times are really not a big deal. It's only 15-25 seconds on average. Enough time for you to grab another beer in the meantime. :D
Yea, and to get rid of the 30 or so KOF's, that's a big deal! Not to mention all the "+" hacked versions.
As far as use on a multi-slot system, you will have to solder a jumper or 2 across the jamma card to allow it to work. Well documented fix though.
All you need to do is run a jumper wire across the board from on two pins (D/26) so that the slot selection button on your CP can connect. For some reason they did not connect that through on the pass through/daughter board. Apparently they don't have multi slot boards in China to test on.
