NEO 29 #15 Coin switch #3 P1 Used or not?
Krusher
Donor 2015
Montebello, California
OK, I Think im in the home run express EXCEPT the -5 volts.
But from taking this switch out, Is coin switch #3 P1 used on a Neo 29??
I know there is only ONE single money slot, and I didnt think of bios issues until now, But im not worried about bios YET.
I am just trying to make this Neo 29 Candy go back to FACTORY wiring.
I bought the jamma adapter and just wanna figure out if #15 on the main
connector is used or not??...
one of the final wires i found NO match for after removing the switch and lableing the wires.
Please let me know thank you.
sounds right.
ok. that sounds right then. I would assume the populated it as part of the switch. I heat shrank it and left it in place then =)
Coin switch #3 and 4 are not hooked up on the MVS harness in my Neo 29 - there is nothing connected to those pins at all...
