Needed bolts on a PC10 Single?
msignor
Sparta, New Jersey
Both of my PC10 single monitor cabs have 3 bolts that are for the monitor mounts, but there are also 2 more bolts on each side just behind the mounts that are vertical. I assume that they were there if someone wanted to convent to a vertical mount game, no?
Would it be adulterating the restoration if I just filled in those extra holes or would it be better to keep it 100% original? I don't really know how it came from the factory so that's the only reason I ask.
I can get a pic later today if needed.
Thanks!
Depends if u ever plan on converting again. I filled mine in. Worse case is if u ever decide to convert ...u can just drill them out again. If u fill them in u will still see the holes from inside the cab...in the future u will know exactly where to drill. Up to you.
