Need wiring schematic for a WGK4951
Starting from the front (closest to you)...
Red
Green
Blue
Ground
Positive Vertical Sync
Positive Horizontal Sync
Empty
Ground
Negative Vertical Sync
Negative Horizontal Sync
What game is it?
Most likely you just connect it to the negative Horizontal sync...
Trying to test it inside my Smash TV conversion cab. The wiring adapter for the monitor currently in it (K4600) is set up as you listed with the video sync in the neg horiz position, yet when I plug it is, all I get is zigzag lines. The monitor in question works fine when hooked up to my pac cab and the monitor currently in the Smash TV cab works fine, but has burn in, so I know it is not the board or wiring. Seems like a sync issue to me, but I am new to all of this. :)
Are you sure your monitor is not a 4915 (vice 4951)? The 4915 is a med res monitor and will not display Smash TV properly. The good news, if it is a 4915 it is in fairly high demand so you shouldn't have any trouble trading it for a standard res monitor.
Did you try adjusting the holds once it was hooked up? Don't just assume that the hold settings for one game are the same as another...
Using a Smash TV board to test. The Label on the monitor says 4951, so it should work, correct? I will have to play around with the v/h hold tomorrow to see what happens. Thanks to everyone for the input.
