Need two quick measurements on original Ms Pac Cabinet
brzezicki
Maryland
Hello can anyone help me out? I'm restoring a Ms. Pacman cabinet and putting on the phoenix arcade vinyl
Unfortunately I forgot to take measurements of the graphics placements before I sanded off the sides.
Can someone tell me the distance of the bottom of the cabinet to the beginning of the yellow stripe as well as the front of the cabinet to the beginning of the yellow stripe (see attached image)
Thanks in advance!
Here you go... 1" from the side, about 3 3/4 from the bottom.
side 1 down.. was going perfectly till I hit the middle and then the lose space near the monitor started catching.. though it would go bad really fast but ended up coming out great. a few bubbles etc that I popped out with a pin.
next side I"m going to use a shipping tube to keep it straight to avoid that again. but 1 side is enough stress for today! thanks again for the measurements, much appreciated.
-brian
