- Joined
- Jul 29, 2019
- Messages
- 785
- Reaction score
- 923
Hi gurus!
I have a 25" K7000 that came with a game I bought. It doesn't focus perfectly and the red is dim even when the gain/cutoff are turned up.
On a whim I bought a cheap 25" TV off FBMP this morning after looking up the typical tube from that model. I pulled the tube from the old TV, connected a chassis to it, and it works, but the image is way too short vertically.
Here are the specs:
Original K7000 Tube: Zenith A63ADG25X
New tube: Zenoth A63AGD01X
(Yes, one is "AGD" and one is "ADG")
Original Tube Yoke:
Red/Blue: 2.2 Ohm / 0.952 mH
Yellow/White: 7.8 Ohm / 12.45 mH
New Tube Yoke:
Red/Blue: 2.1 Ohm / 0.88 mH
Yellow/White: 5.4 Ohm / 6.4 mH
The image only fills about the middle 1/2 of the screen from top to bottom through. If I max out the V-Size pot, the image folds over and gets really stretched out, and still only fills maybe 90% of the screen. However, the colors and focus are great, much better than the original tube. You can see that here. The fold over is at the bottom… I had to reverse one pair of yoke wires to flip the image and hadn't done that at the time I took the pic.
I'm guessing the image size is a sign that the yoke is too far out of spec for the chassis and I will need swap the yoke if I want to use this tube, is that correct?
I've seen a Reddit thread where someone claimed to swap this same tube on a K7000 and it worked fine, and a KLOV thread from some time ago about the same tube where the poster had to change the width cap but no indication of vertical height being an issue.
Here are the specs:
Original Tube Yoke:
New Tube Yoke:
