Need to know the correct molex pin size
SuperBee4406
greenville, South Carolina
I started to change the monitor connector on my Asteroids Deluxe today, and found the molex pin size I was using was the wrong size. I was trying to use .093 size. and when I crimped a molex pin onto the wire and then tried to insert back into the plastic molex connector, it doesn't fit, not even close.
What is the correct pin size I need to use?
The connector on the end of the monitor's input harness (to the cabinet) is an AMP brand "Mate n Lock" connector. It is NOT a Molex.
