need tempest inside cabinet pics so i can finish wiring up mine - help
cleverlyj
Northglenn, Colorado
so i'm just waiting for the mailman to arrive so i can get my ar2 rebuild kit and wg6100 kit, and i should have an operating tempest.
however, i need a couple pictures to specifically show wiring so i don't f it up... if someone can provide these i'd really appreciate it.
1. i need a pic showing the ar2 board with the wiring plugged in, close enough that i can see where each plug goes. - reason being that there are 2 6 pin molex connectors that are identical, and i don't want to plug one in wrong.
2. i also need a close up on the edge connectors for the boardset, and which way they plug in. if you could get close enough that i can see the wiring and wire colors so i can match mine up, that would be much appreciated. i had to reinstall the harness on this so again i want to make sure everything is plugged in right before i fire it up.
thanks,
jim
main.php
thanks jeff. do you or anyone else have a close up of the ar2 with all the wiring plugged in, and also a close up of the edge connector wiring plugged in on the boardset? the keys aren't in mine, so i don't want to install them backwards...
Here is a couple shots from the nasty project cab I got last month:
thanks very much. now i just need pics of the edge connectors plugged in to the pcb so i get them plugged in the right way. thanks guys for the help.
You mean this:
Of course I should probably let you know that this Tempest is currently dead. It does appear to be all original. The serial numbers even all match. But you might want to check with someone who has a working Tempest to ensure that the PCB edge connectors are installed correctly.
Here's a pic from one of the restorations I did a few years ago. I think the wiring harness I bought was from an Irish cabinet, so I'm not sure if the wire colors are the same or not.
