I got this machine in partially working order ( as in lights work) and trying to troubleshoot it and made some progress but now stuck again. After it powers up when the ball is in ball trough it will not kick the ball out to the plunger. If you pull the ball out and play it will score and misc. Another problem probably related to first problem is the out holes will not recognize either. No fuses are blown on main block on bottom of cabinet or the one on the playfield. I have cleaned the contacts also but it seems like that is not a problem also.
When the game is in its start-up routine when you push the start button and you push the switch under the playfield and see the solenoid switch moving but it seems like it is not getting a lot of power to kick the outhole solenoids. If you hold it down it will kick the outhole solenoids after the 4-5 clicks give or take since it is going very rapidly. Any ideas on what I should check next.
