Mark Hooks
I can't seem to get the horizontal sync to lock in on the G07 I put in Qbert. I've tried adjusting it to no avail. Which wires do I connect and to which set of pins?
What's it hooked up like now? If I recall correctly, you need to jumper the tow negative syncs. Can't get to mine right now to look. If it had a WG in there originally, it might not have a wire for the -vertical sync....
Pull that last wire all by itself and move it to the connector behind the big one. Use the last pin on the left and see if that fixes it.
Do you know what monitor was in it before?
That wouldn't work with a G07. If it was composite negative, it would have to be connected to both the middle and left pin of that three-pin connector...
