Need Super pacman control panel pinout
JoeB1355
Seymour, Tennessee
I finished wiring everything up but I'm not sure what wire goes in what pin -- the schematic wasn't helpful....
here 's a pic -- Can anyone help what wire goes in what hole
I'll try to grab pictures for you later
also here's the wiring diagram from page 9-1
Yeah I have the schematics it just only has the pinouts to the board not the connector on the harness unfortunately
Is the control panel already wired and do you have access to it? If so, just follow the wires to the connector and match them on the harness side. I thought this might be helpful, but then I realized that it shows a 13th and 15th pin and your pic shows a 12 pin connector.
I don't have the full harness nor do I have the CP harness -- all the wires were removed from my game for a conversion by previous owner.
I wired up all the of the control panel, buttons buttons joystick ground , but now I want to put the wires in the connector at "right" place in case I ever get a real harness it would plug in correctly.
Right now I'll just make a jamma harness match it until/if that day ever comes that I get a real harness. The schematic just shows the pinouts for the circuit board but not the control panel connector nor the coin doin connector.
So I'm still looking for the info.
Here's what I got. Keep in mind this is a super pac cocktail. This is the one player side, so it theoretically should be the same as a stand-up.
Thanks! That was perfect. Since my wire colors didn't match(I used misc wire scraps) I needed to correlate them to the schematic. So for future reference (for the next guy) here's what I ended up with. The numbers match my first picture
1 NC (GRY-R Control panel light cocktail)
2 NC
3 NC
4 B-Y P1 FAST
5 Y-R GND
6 NC (ORG-B Control panel light cocktail)
7 W-R P1 RIGHT
8 G-B P1 DOWN
9 B-G P1 UP
10 BLU-W P1 START
11 BLU-B P2 START
12 R-W P1 LEFT
Mark was also able to get me some pics for the coin door connector so I could get it figured out as well
X D X
X X X
D X D
1 2 3
4 5 6
7 8 9
1 GRY-R => Coin Lights
2 ORG-B => Coin Lights
3 Y => Ground/Return
4 BLU-Y => Slam/Tilt
5 BRN-B => Coin Switch 2
6 BRN-W => Coin Switch 1
7 W => Coin Meter
8 NC
9 W-Y => Coin Meter
X D X
X X X
D X D
1 2 3
4 5 6
7 8 9
7 W => Coin Meter
8 NC
9 W-Y => Coin Meter
