Need space invaders paint codes white/red/blue
knight rider
Illinois
Restoration of Space invaders
Re-doing the cabinet and I needed the factory or close to it color paint codes. I have the blue and red colors
So, this is what I am starting with
John
So, I filled and sanded the whole cabinet fixing anything along the way. I primed it all around a few times.
Ok, so I got the final colors of white, and black. So, after priming the cabinet. I now have finished with the final coat of the blue and the final coat of the white. Take a look......
Ok update::: I have the small stencil kit for the sides and the front. So I got it all ready and started with the red.
So, after doing the red, using a roller, this is the final result of the red. I put 3 coats on the front and both sides. Final result....take a look
Ok another update. Heres the black pulled off, the front and both sides final result. Have to do some minor,minor touch ups and that would be it for now on the stencils until I get the main bigger ones.
How are you applying paint? What type of paint
I have two sideart projects I have to work on. One is for a Defender cab, but I also have a Space Invaders cabinet that needs major work.
Could you describe what paint you are using, where you procured it, and how it was applied?
thanks.
By the way if you are interested, I track my restorations on my blog at http://mygaragearcade.blogspot.com. So far I fixed up a Ms Pacman game, but I've finished getting the Defender working and now want to fix up the cabinet.
Thanks Rich, I will be getting the rest of the stencils from you soon. Nope its blue. I have to change that to black. I just added in the front t-molding also today.
As far as the post above, I used a 1/4 nap roller to put the paint on. I sanded and filled anything I thought was bad on the cabinet that needed to be fixed. I primed it then sanded and re-filled anything else that needed it, then re-primed again. Once finished primed, I then painted it with the colors.
