Need some wiring help on a dedicated TMNT cab
UnknownMK
Pennsylvania
Can someone take a pic of the inside of their cab so I know what leads these wires go to?
No idea why you would cut it off but I'd like to get it reconnected.
A pic of someones cab won't help you at all. I would start with, where do those wires go in your cab? What is that ground strap attached to?
Oh, well I figured if they also have a dedicated cab, the wiring would be the same. But here's a few more pics:
The blue and brown wires run to where the toggle was and into the door switch. The red and black run to the fuse, the red and black with the white stripe run to the isolation transformer and power supply and then into the door switch. The ground strap runs along the bottom of the cab where the iso is and up the side of the cab.
Somebody must have a dedicated cab that can help a brother it with a pic of the power switch. Anyone??
