Need some random Williams pinball parts
HHaase
Sioux Falls, South Dakota
Doing a playfield swap and a few other oddities. Need a couple oddball parts.
Needed:
1 WPC style knocker assembly.
6 playfield sleeve posts, 6-32 thread on the bottom with no threads on top.
1 assembly from Black Knight (or same type from another machine) that kicks the ball into
the shooter lane, don't need the coil holder/coil part, but I need the rest.
-Hans
The playfield sleeve posts, do you have a pictire of what you need?
I pulled a bunch from a Hyperball playfield that may work for you.
Edit: Here's what I pulled. They are not new, but if you can use them, I will dig through the box to see how many I have.
Chris
Those are pretty much what I'm looking for. How tall is the actual sleeve on there? I'm looking to use the Cliffy sleeves, which are 1" tall.
I'm not too worried about the rust, I can throw them in the bead blaster or tumbler if I need to. I can use at least a half dozen, with maybe a couple spares in case of bad threads or if I counted wrong.
-Hans
-Hans
I think the sleeves are about an inch, I will measure them tonight and dig to see how many I have in the box. I have ALOT with the threads on top, but I don't know if I have 6 without, but will check tonight when I get home and let you know.
Chris
Needed:
-Hans
Do you have a picture of this? I have some parts from a Pharaoh and may be able to help you out.
