GMZombie
ok so i have 2 of these chassis with no power. first i thought i would replace the hot. did that and no luck still dosent power up. now i setup my station so i was able to take some readings while its hot and here is what i have. from ac power in i had a 48vac on one side and a 55vac right at the ac in. followed power on each side till it hit a d101 which is a 4 pin what im assuming a diode and when jumping from 1 pin to the next it goes from 55vac to 1.9vac and the 48vac goes to 1.16vac. just to be sure i checked it in dc and there was no volts. i checked r117 and there is no volts on either side. please advise next route of action as im stumped
