The two vertical out Transistors located on the large heat sinc could have a broken solder joint or a leg broken. Opens up after its warm. If you want i could help you take a look at it, not sure i would be alot of help, but i live right around the corner from you, talked to you on the phone once about the pacman im restoring
-Matt
