James_in_MD
I have a G07 in a Spy Hunter. I have sync problems. This seems to be a common problem, especially with SH's. I have read up on previous posts, and that has helped. I still have sync issues however. The mon seems to respond in an unstable manner when I adjust the Horiz Freq pot. It's very sensitive to small movements to the pot. Also, adjusting the Vert Hold will make the screen scroll horizontally - is that normal? I checked the voltage coming into the monitor from the Iso and it read 118.3/118.4. I guess that's okay. I measured the voltage just into the chassis at R01 and it came up 260. I guess that is pretty F'ed up. I went to adjust the voltage at R909, but then I realized the pot had a bunch of white crap jammed into it and protruding out of it. I kinda looks like thermal paste or white putty or some such thing. It was still pliable and I could scrape it off to some degree, if I needed to. I just wanted to ask here if anyone has heard of such a thing. Why gum up a pot with this putty? To prevent someone from mucking with it is the only reason I can think of, but I am a noob at this stuff. ANy help will be appreciated.
