Need repair help
Wynn67
Georgia
Hi. I am new to this board so...sorry if this question is a waste of your time.
I have a Sega Turbo. It works fine except for the gas pedal. It just stopped working. Press it and nothing happens. Do you do work on these games? Have any suggestions on how to fix the problem or know who on this board might work on these?
I also have a stargate. The monitor on it will work sometimes and then flicker and there will just be a thin line or two in the middle of the screen or at the top or bottom. Do you think that is the monitor or the board? If the board, do you work on them?
Thanks for your time!
Wynn
Welcome o the forum,
The gas petal problem might be as simple as a mechincal thing that has gone wrong or he variable resistor pot that is broken. A digital multi meter on ohm resistance reading will tell you quickly what your problem is.
As for the two lines that show up. That sounds like a Board issue. Hard to say really. Williams boards always seem to have issues from power supplies to wires that inter connect to battery acid damage. Send an pm or email to those who post in the thread Who repairs what to find some one..
