Need references on Tron side art
Dantebean
Norway, Iowa
Going to put down a lot of $ on Tron art. Anyone got experience with certain sites for this. Price vs quality? Any collectors have left overs not needed. Will be purchasing ASAP.
Side note: looking for Tron power supply upgrade info if anyone has done it. Can this noob do it?
Thanks gents.
There are no options. Phoenixarcade.com is the only place you should consider. DO NOT waste your time on eBay or other sellers (don't cheap out getting an Arcadeshop CPO or something like that). Just buy the entire package over there and don't look back...it's like going to DisneyWorld.
I 2nd that. Darin is the man on Tron art.
+1 on PA, as for PSU upgrade well worth it, friend has a Tron, and he had the PSU rebuilt, and still was flakey, got the switcher kit and it has ran eversince, and even survived David Cruz putting on an insanely high score on it at our Arcade Show :)
and was easy plug and play (heck I did it! so must be easy) :)
Thanks guy, I may go power supply from arcade shop first then. So I order the Mcr from tem and the heavy duty switcher?
Yep I got the kit and HD Switcher from AS, works like a charm :)
and still working good now, after another year of our Show, and David beating it down, still plays good
It's so sad to read these blasphemous suggestions to replace a superior linear power supply with a pos switcher. It's a down grade to use a switcher. Do it right and re-build the original supply.
+1 the brick and 90412 is a good power supply if rebuilt with care and quality parts. Besides, switchers in brick cabinets look dumb. (IMHO)
