Need Pics of GT Fore or similar cabinet
dwagler
Iowa
I have a GT Fore cabinet and the monitor was missing. I have four brackets that get installed into the cabinet with carriage bolts, but i can't figure how the direction they go. I also would like to see if there are some additional pieces that attach to the brackets that attach to the cabinet. If anyone has a cabinet sitting around that is missing the monitor, i would appreciate some pictures.
you can email them directly to dwagler @ aol.com. too if you would like.
There are black upper and lower brackets which the monitor mounts (gold) attach to. My machine was missing the chassis for the 25" when I got it, so I made my own mount and replaced the whole thing with a 27.
This pic kind of sucks, but you can see the black bars. Hope it helps.
If you're talking about the four corner-piece brackets, they go in with the bolt pointing towards the control panel (obviously), with the L shape in the bottom left, upside down on top left, then mirrored on the right. The monitor should have a bracket that goes across the top and bottom with holes that match up with the bolts, then nuts hold it on.
The monitor is heavy, so have someone behind to help support the monitor as you put it in until its on the bolts. Don't break the neck...
