I don't think that I'm searching correctly. Any leads is appreciated.
I'm looking a YPN 153J 630V N15 cap as pictures.
that should be a .15uf 630v (J) which is 5% tolorance
It's 15nF 630V.
You should also pay attention to the spacing across the leads or you may end up with something that won't fit the board. In your case I think it's 22.5mm but you want to double check it.
http://www.digikey.com/product-detail/en/epcos-tdk/B32613A1153J008/495-3591-ND/1647872
http://www.digikey.com/product-deta...onic-components/ECW-H16153JV/P10509-ND/269129
The panasonic is probably a slightly smaller lead spacing than whats on the board but with the extra long legs you should have no problem fitting it.
.015uf = 15nf
.15uf = 150nf
0.015 uF / MFD OR 15 nF OR 15000 pF (MMFD) (all three have the same capacitance value but all three are just expressed in different grades of the Farad SI unit.)
all of the above are the same your only moving the decimal to read it in pico-farad (pF) OR nano-farad (nF) OR mikro-farad (mF,uF eller mfd) which all three above are the same value of capacitor. look at Table 3 on the link which hopefully explains it better. http://kaizerpowerelectronics.dk/theory/capacitor-code-table/
yes the link is the correct one you need http://www.digikey.com/product-detai...591-ND/1647872
Appreciate the information. So it looks like the below link is the correct capacitor to order. Correct me if I'm wrong. Thanks
