need: JR PACMAN SPEED ROM IMAGE
original board or conversion board? Is there a difference? I thought the conversion board used the same speed up chip that pac and ms pac used...
The only difference between the conversion board and dedicated is one is AC and the other is DC. Both use the same roms. I sent the speedup file to your email.
From what I've been reading, are all 3 Pac's Pacman, Jr-Pacman, and Ms-Pacman speed up ROMS all the same?
If so, which one is the ROM on Jr-Pac?
I have a Ms-Pc that has the speedup ROM and I don't like it. Want to put it back to normal speed and I have a Jr-Pac I'm working on now, so I could use the ROM from it if it will work for now.
Anyone know?
Jr Pac does NOT use the same speed up chip as Pac and Ms Pac. Jr uses 2764's, which are physically larger than the EPROM's on any stock Pac or Ms Pac board. It's different code anyway, even if they did use the same size EPROM's.
Well, I was hoping to not have to buy one if I already have one. That's really what I was trying to find out. If the Jr-Pac ROM was the same as the Ms-Pac ROM and which one on Jr-Pac would it be. They are not numbered the same.
