Need info on monitor for 4 player simpsons game
knight rider
Illinois
Hi, anyone know what size and who made the monitor for the 4 player simpsons game??
Not the bowling one, but the fighting one 4 player??
Wow, I remember that title as your avatar, I use to play that on the commodore 64.Long time ago...... Anyways, yes have another question for you. Thanks for the reply above. Will my monitor from a sega title fight work for the simpsons game? I ask becasue theres a 19 WG in there and want to get the simpsons back to the way it wa original .
ok, thanks. how do I verify that??? I look on mine over here and it says Nanao MS8-26SU
Then you have a Nanao monitor, not the WG specified in the manual. That is not a big deal, manufacturers often just put whatever monitor they had in the machines. The biggest thing you would need to watch out for would be the monitor resolution, but that shouldn't be a problem in this case. You should look at the Simpsons cab to see how the monitor housing was modified. The 19" would have needed some kind of modifications in order to make it fit...
Thanks for the info, I plan on making the correct size cabinet. The one I have is so small. I posted a picture on here the other day, check it out if you can. How do I convert the wiring harness over to match the other monitor since this is already not the factory harness for the simpsons game. I know this trying to t/s the coin door and the pin connectors and the wire colors dont match up to the drawing
Ha! Yep its a CLASSIC! :) In a day before the PS3 and Xbox360! Kids today are spoiled!
I wouldn't see why it wouldn't work? I would think any standard K7000 25" would work just fine? If you needs some pics of the mounting or anything else, let me know
sure send me some pictures if you can that would be great. I dont have the monitor you mentioned, I have the Nanao MS8-26SU in there
Is this about that Gauntlet cab? That is not an original Simpsons cabinet. It is a good candidate for conversion to a Simpsons game because of the large control panel but I don't know that a 25" monitor will fit in the cab. This is why your drawings don't match.
Hey Knight Rider, I did a complete resto on my Simpsons cab this past spring. I have a TON of pics posted of the entire process over on the BYOA resto forum. Check them out, should answer a bunch of your questions.......
Awesome, I will check that out. Do you have a link to it?
I also plan on building a cab and not use the gaunlet cab at all
AWESOME!!!!!! thanks for the link. and also THanks for everyone info and help on this, thanks again.....
Do any of you guys have the cabinet dimension drwaings for the simpsons? I saw this site that had alot of cabinet drawings but it doesnt work when I try to download.
knight Rider,
that is a standard Konami cab, a bunch of game came in it, TMNT, Xmen to name 2 otheres off the top of my head
