I have a Frogger machine that is getting a new vertical monitor. The old unit was mounted with some plywood... looking for a pic of the original mounting of the monitor to compare. All the images I've found so far are hacked up. Please post. thanks
I've seen several different ways Frogger had monitors mounted in. Mine does not have a frame as seen above. The chassis (G07) is screwed down to the bottom plywood....
I have an original Frogger cab,and mine looks like the one in the pic above.If you want to see that,search the threads for "Frogger restoration challenge"
This your lucky day. I happen to have my Frogger monitor out of the cabinet for a cap kit. It's the original WG K 4600 vertical mount. It bolts to a wood frame. Here are some pictures I just took a few minuets ago.
It's interesting to see how this was done on different cabinets.
My cabinet is an original japanese Frogger unit and the monitor braces that are mounted to the cabinet walls are completely different than the images above.
