Need help with Stern Frenzy board set
disjaukifa
Ridgeway, Virginia
Hey Guys,
I got my Stern Frenzy on Saturday (amazingly long haul . . .) ANYWAYs, I can't seem to get pass the 4th Self Test on my Frenzy. I've got two Berzerk's and a TON of spare boards (literally I have multiples of each) and no matter what combination I can't seem to get past the 4th self test.
The only thing I just noticed was that my 12+ line is only registering 11.91V instead of 12V, would that cause the game not to boot?
Also to make things even more interesting I tested bot the BSC-1000 and VFB-1000 in my working Berzerk Fast Bullets machine so I know those two boards are good. Also I know for a fact that the Frenzy ZPU-1000 is working as well.
Any help or guidance would be appreciated!
Disjaukifa
Ribbon cables? 4th beep is either the VFB or BSC ram.. Also check the -5 volt line.
Hey mcanderwsoun,
I checked all the ribbon cables on my working Berzerk, so that works, checked the VFB-1000 board on my working Berzerk as well. I checked the voltage on the 5+ and 5- and both were between 5.00 and 5.25, I think both were hovering right around 5.10.
Maybe I just need to take my BSC-1000 board and stick it in my Berzerk too see if thats bad. I've got 3 others as well, hopefully I can get one working :eek:
-Disjaukifa
