mrdion
Hello,
is there anyone can shed a bit hint on how to track down bad RAMs problem on sega model 2b crx, namely last bronx?
test menu screen attached.
see, the problem is when i replace a ram, it stills marked bad. what even wierd is, when i pull of ram @IC64, the test at ram 64 still shows GOOD. so i am bit confused. is the test number misleading?
thanks in advance
thanks in advance
