Need help with Premier Crane claw machine manual
toozie21
Does anyone have a Maxtrol MAX-3700 manual? They are used in claw machines. I got a manual with the unit I bought used, but I can't seem to get it to change the cost per play settings, so I think something might be off. The claw machine seems to work OK, I'd just like to make it free to play since I have it setup in my garage.
I believe there is no free play setting, don't recall seeing any in the manual.
What I thought it allowed was the option to play until you won. So, poorly worded on my part, but it would mean it would be a lot easier to play a bunch of times than right now 🤣.
I'll have to look at a manual, not to complicated. Just don't remember.
Here are the instructions.
If you wanted a play until you won game, you should have got an AGE crane. They had that feature.
There are flat pressure sensitive buttons you can buy which have a flat cable that goes between the coin door and frame, that you can press to provide credits, or rig a momentary pushbutton off a bracket on the coin return button, so every time you press it, you get a credit.
Thanks, that is the same as I have 😔.
GregandValerie Lilly "one they recommend" meaning Amazon?
If I press the button in the middle of the board to get to the menu, the attention-grabbing 7segment LEDs will pause while I am holding it down, but start back up when I release it (instead of going into the menu). Have you seen a similar issue like that? I was hoping you had instructions that were different and that would allow me into the menu, but no dice.....
there are flat pressure sensitive buttons you can buy which have a flat cable that goes between the coin door and frame, that you can press to provide credits, or rig a momentary pushbutton off a bracket on the coin return button, so every time you press it, you get a credit.
Do you happen to have a link to this sorcery you speak of?!?
Check your start button may be aired nc instead of no, had that before.
Even though once credits are added, the game doesn't start until I press the button? If it was connected to NC, I would think that it would start as soon as the credit hits the system (plus it doesn't use the next credit until I press it again).
