mecha
what about that TBA 530 chip? I had one of those go bad but it made the screen effectively inverted loland yes.... you're missing Green so that's likely:
I'd connect a TPG (or another game) to that monitor and confirm it's not a monitor issue first. If not, it's likely the RGB board or connector between RGB board and the monitor chassis.
- bad chip on RGB board (small board between cage and monitor)
- bad connector or wire to monitor
- monitor issue
- bad transistor on PCB stack
also I believe we got a replacement from APAR so they're not unobtanium yet
