Need help with Big Choice claw machine (80's?)
Vaxkiller
Pennsylvania
I have a Big choice claw machine that I think to be from the 80's. It has two buttons to direct the claw.
I have 3 boards for the claw machine and all them are exhibiting the same symptoms.
If move the claw mechanism will got back to home position, but the "start" button does not work (a button put in to simulate a coin) I test this button on a meter and it goes open/closed.
The "UP" button does nothing (moves the claw away from you. But the "right" button (moves claw to the right) does actuate the relay (nothing else does) I swapped the 3 relays on the board around and every relay works in the slot that controls the "right" button. Swapped out board with the SAME effect. Disconnected the entire claw assembly with the same effect. Disconnected the lights for the right and up buttons still same thing.
Any ideas?
-Vax
there were different versions of big choice cranes
1 had the 2 buttons that moved back and then moved right and the claw would
drop after you let go of the 2nd button.
The other had a joystick that allowed the player to move the claw around left, right,
forward and back as much as they wanted until time ran out or you pushed the drop button.
I am not sure if the boards are the same but different dip switch settings or all together different. You might have the wrong board or wrong setting?
also if the claw string is wound up backwards or not proper, when the claw goes down,
it really is trying to go up which it can't and causes the crane to usually freeze in that position?
I got the one with the 2 buttons. The claw works ok (If I power off the machine and drag the claw down it will return to home position)
THe problem is I cant get it to start! Usually when a coin (or in this case a button is pressed) it triggers a relay, but I cant get the relay to trigger. THe relay works however because there is one relay that DOES trigger and that is the "right" directional button, and swapping the relays around, they all work in the slot where the right direction button actuates it.
when you put a quarter in,, does it trigger the lock out switch on the coin mech?
the two smaller black relays sitting side by side on the pcb activate that.
then the lights to the coin door should shut off until your turn is over.
