mike11
Ok in the process of trying to get a project ms pac working I got, heres the story so far.
At first I had nothing, Then I began playing with removing and reseating chips and started getting the board to beeot and see garbage on the screen, numbers random ghosts and ms pacs, kept going and when I got to the 6H chip almost all the legs were about burned off and most broke when I popped it out. Very Carefully I seated it the best I could cleaned the tops of the legs and inserted tiny pins into the socket and soldered them to each remaining leg on the chip. also reseated all other ships as well..... Now I have this for an image with the sound of Ms Pac munching and some of the blocks moving from right to left .... ghosts come and go ............Where next >>>?????
