Game credits up, score resets to zero and shooter kicks ball out to chute when you hit start button but will not score and flippers and bumpers do not work. Appreciate any help.
All fuses are good. Checked with meter. Yesterday the flippers worked briefly. I think I was making sure that leaf switches on The 1s 2s 3s DB XB SB and tb bank were adjusted correctly. My knowledge of em pins are limited. I bought two em pins. Both only turned on but with some research and going thru all the leaf switches I got them running. But now I'm stuck and want to get this thing running again.
Hi - Mr Obvious here while your at it check your step units to make sure they're moving freely...If you jerk the game after start up does it go into tilt? If it does it's not tilt...
