R3LL1K Well-known member VAPS Joined Mar 3, 2009 Messages 3,471 Reaction score 32 Location Houston, Texas Sep 9, 2009 #1 Here's a pic.
2600 Well-known member VAPS Joined Sep 22, 2005 Messages 5,197 Reaction score 231 Location Ashburn, Virginia Sep 9, 2009 #2 What do you want id'd the uf, Voltage rating, or size? Looks like 10uf 16v. You'd have to look at a datasheet for sizes, but it's probably one of the smaller ones.
OP OP R3LL1K Well-known member VAPS Joined Mar 3, 2009 Messages 3,471 Reaction score 32 Location Houston, Texas Sep 9, 2009 #3 2600 said: What do you want id'd the uf, Voltage rating, or size? Looks like 10uf 16v. You'd have to look at a datasheet for sizes, but it's probably one of the smaller ones. Click to expand... I wanted to know the uf and voltage. If it had a V after the 16 instead of the S, I would have assumed this is what it was. Thanks for your help!
2600 Well-known member VAPS Joined Sep 22, 2005 Messages 5,197 Reaction score 231 Location Ashburn, Virginia Sep 9, 2009 #4 Do you have a schematic for the circuit or know what the input and output voltage should be?
OP OP R3LL1K Well-known member VAPS Joined Mar 3, 2009 Messages 3,471 Reaction score 32 Location Houston, Texas Sep 9, 2009 #5 2600 said: Do you have a schematic for the circuit or know what the input and output voltage should be? Click to expand... These are on a Neo-Geo MVS cart so I was just going to put a 10uf 16V cap in.
2600 Well-known member VAPS Joined Sep 22, 2005 Messages 5,197 Reaction score 231 Location Ashburn, Virginia Sep 9, 2009 #6 Yeah, I'd think 16v should be fine for that then.
